Mach Discussion => Mach4 General Discussion => Topic started by: SEREGIUS on November 23, 2017, 04:21:06 AM
Title: Mach4 - Laser cutting machine & "FlyCut"
Post by: SEREGIUS on November 23, 2017, 04:21:06 AM
Hello to the whole forum!
Use Mach4 on the laser cutting machine. Want to cut the metal "FluCut" method.
Here's the video:
https://www.youtube.com/watch?v=rDlE9u3H_iU
but I can't.
The picture shows a test GCode.
M3 - lowered the torch and turned on the laser.
M5 - turn off the light and raise the cutter.
M203 - includes only the laser cutter remains in the gap.
M205 - turns off only the laser cutter remains in the gap.
From the code M3 to M203 cutter moves smoothly, without jerks. Starting with the code M203 further, the cutter begins to stop completely. I use high acceleration and speed of the motors, the machine starts to twitch.
Is it possible to get Mach4 to cut through the metal as in the video above??
Title: Re: Mach4 - Laser cutting machine & "FlyCut"
Post by: Tweakie.CNC on November 27, 2017, 12:56:43 AM
Hi Seregius,
I have replied to your post on the Warp9 forum.
Post by: SEREGIUS on November 27, 2017, 05:52:15 AM
Thank you, Tweakie.CNC
A solution has been found.
