Mach Discussion => Mach4 General Discussion => Topic started by: rhtuttle on November 13, 2017, 12:46:40 PM
Running PMDX 411 and Gecko G540 on build 3481 on a lathe.
I have a cheap opto sensor on my spindle that works very well reporting the actual spindle speed as verified with a tach.
I noticed that when I issue a M5 that the Dro that shows the actual speed does not return to zero for about 3-5 seconds from the time that the spindle actually stops spinning.
Does anyone know if this is due to the opto, PMDX or Mach4 not updating?
I was using this DRO value to check to see if the spindle had overloaded and stopped and it was not disabling movement promptly.
Is there a better way to handle this? (I am electronically challenged so hopefully I don't have to create some citrcuit ;D)
TIA
RT
Hi RT,
I think you'll find that Mach does a significant averaging on the opto input and will therefore suffer a significant delay.
I believe there is some control over the averaging, you can reduce it but may then encounter problems that it is not
sufficently stable for threading.
A genuine encoder is required to give you the bandwidth that spindle overload protection requires if you require near instaneous
crash protection.
