Mach Discussion => Mach4 General Discussion => Topic started by: acourtjester on November 07, 2017, 05:59:29 PM
Title: problem with probe action
Post by: acourtjester on November 07, 2017, 05:59:29 PM
I am a new installer of Mach 4 on a router table, my progress stopped at the touch module function.
When I click on the find Z tool surface Z moves down and the probe trips and nothing else happens. >:(
The probe indicator shows when the probe make contact and not when it is not in contact so that is correct.
I expect the Z to retract and set the Z DRO to 0.0 this does not happen. :o
I am running a PMDX-416 USB board and that is the only plug in I have enabled and Mach 4 is build 3284
Hope there is help from someone here.
Title: Re: problem with probe action
Post by: acourtjester on November 08, 2017, 09:39:11 AM
Ok my problem seems for be fixed I received a reply from Tech Support for a change to the "Probe feed rate" and a change to the Lua file from Mike Abbott.
 https://www.pmdx.com/PMDX-Forums/index.php?topic=356.0
 Also I was using a wire touch for the testing the probe test and I found I was to fast with the touch.  If I held the contact for a short time longer is would work correctly.
Many thanks to Bryanna for quick replies to my questions.
