Mach Discussion => General Mach Discussion => Topic started by: pudly123 on October 31, 2017, 05:18:44 AM
Title: Change direction of workpiece
Post by: pudly123 on October 31, 2017, 05:18:44 AM
 I finally got everything up and working, thank goodness!
 However, I have a project file that involves drilling several holes down the length of an 18" board. When I run the file, the machine seems to assume that the board is placed horizontally on it. It is a CNC 6040, which is approximately 19" wide. Therefore, there is not enough room to drill the holes with the spindle going side to side.
 I need it to assume the board is placed in the machine along the the length, not width.
 Is there a setting in Mach3 so I can change the direction of the board and the machine will recognize this?
Title: Re: Change direction of workpiece
Post by: Tweakie.CNC on October 31, 2017, 06:46:02 AM
On the MDI screen is Local System Rotate, just enter 90 (or -90) and that should do it. Please be aware that your datum will also be moved.
