Mach Discussion => General Mach Discussion => Topic started by: jbvmag on October 18, 2017, 08:50:12 AM
Title: Mach3 Homing/SoftLimits Home Off Column?
Post by: jbvmag on October 18, 2017, 08:50:12 AM
In Mach3 Homing/Softlimits, can someone tell me what the "Home Off" field is used for?
Title: Re: Mach3 Homing/SoftLimits Home Off Column?
Post by: ger21 on October 18, 2017, 10:47:48 AM
It sets your home switch position to a value other than zero. If you put 5.3 in the Home off field, when you home the axis, it will set the machine coordinate to 5.3.
Post by: jbvmag on October 18, 2017, 01:49:38 PM
Cool, thanks Gerry!
