Mach Discussion => Mach Screens => Topic started by: slow-poke on October 12, 2017, 10:08:37 AM
Title: Custom LED with a unused code ???
Post by: slow-poke on October 12, 2017, 10:08:37 AM
I want to add a few LED's to an existing screen. I will have a brain drive the LED's. However the function of the LED is not a standard OEM type, I want it to be custom. My brain has output to OEMLED: 1001 etc.
How do I create a custom LED on an existing Mach3 screen that will turned on/off via my brain using for example OEMLED: 1000, 1001 etc???
Using MachScreen, when I select an LED, It seems like I can only select from the provided list of standard LED's that already exist on the mach3 screens.
Title: Re: Custom LED with a unused code ???
Post by: Klaus1311 on October 12, 2017, 01:02:56 PM
if you are using MachScreen as your screendesigner, select the LED and enter your ID in the OEM-Code line of the property dialog.
Klaus
