Mach Discussion => General Mach Discussion => Topic started by: parth1799 on October 05, 2017, 03:29:06 AM
Dear experts,
i have question regrading parallel port. can any one tell me, when i activate "modbus input output support" in "configuration port and pin" my parallel port works properly.
means i want to give input signal to mach3 using "modbus input output support" and i want to give output to parallel port for controlling breakout board. both are working together without problem?Huh
i hope you can understand my question.
pls help me to figure out this problem.
thanks & regards
Parth Jetani
yes the parallel port continues operation along with Modbus at the same time.
ok thanks joeaverage
i want to control feedrate using arduino. so using this feedrate i want to control my stepper by breakout board right.
so it is possible ..... now i will plan to buy arduino and breakout board for my WEDM project. thnaks....
