Mach Discussion => General Mach Discussion => Topic started by: Risewiththetides on September 10, 2017, 12:03:16 PM
Title: Need help with mach 3
Post by: Risewiththetides on September 10, 2017, 12:03:16 PM
Hi guys,
I've got a problem that I can't seem to find the answer to anywhere.
When you load your code on standard mach 3 and press start my machine moves the Z axis up 20mm to a safe position before travelling down to proceed with the cut.
Problem is I want to run a job which needs all the Z height I can get and I want to change this initial travel to 2mm or so?
Is this possible?
Cheers, Iain
Title: Re: Need help with mach 3
Post by: joeaverage on September 10, 2017, 01:23:35 PM
can you post the first part of the Gcode... it may be that your code calls for the move that way and it has nothing to do with the safe Z
settings.
Safe Z settings are Config/Safe_Z_Setup
