Mach Discussion => General Mach Discussion => Topic started by: gabedrummin on August 14, 2017, 08:32:02 AM
In the hardware I have connected a mpg to port 2.The Mpg has Channel A, pin 2 Channel B, pin 3 Channel A- pin 20 Channel B- to pin 21 ..In Mach 3 under ports and pins I have Mpg 1 enabled I have A port =2 .. A pin =2,,, B port 2 ,,,B pin =3....How do I tell it I have a ..A-Channel connected to port 2 pin 20 and a B- Channel connected to port 2 pin 21 ? Thank you. You guys are great.
