Mach Discussion => Mach4 General Discussion => Topic started by: wwenter on July 24, 2017, 07:56:33 AM
Hello All
Is there a macro that has been written that would allow me to enter a m41- m46 to change my lathe spindle range in a g code program for mach4
Just read your post.
The macro below does this job for me.
I have defined the spindle range (6 gears) in solidcam and the post pocessor call the macro on tool change.
M101 P <Range>
Hope that helps.
function M101(hVars)
local CurrentSpindleRange = mc.mcSpindleGetCurrentRange(inst)
local NextSpindleRange = mc.mcCntlGetLocalVar(inst, hVars, mc.SV_P)
mc.mcCntlSetLastError(inst, "Sets spindle range to " ..NextSpindleRange)
if CurrentSpindleRange ~= NextSpindleRange then
wx.wxMessageBox("Change Gear to " ..NextSpindleRange, "Gear box")
rc = mc.mcSpindleSetRange(inst, NextSpindleRange)
end
end
if (mc.mcInEditor() == 1) then
M101()
end
Can you explain me better please?
I have to do something similar too.
I do an example:
range 1 (from 0 to 500 rpm)
range 2 (from 0 to 1000 rpm)
range 3 (from 0 to 1500 rpm)
how should i do?
thank you!
A lot of machines use M40 and up to set the range. For example, M40, M41, and M42 for a three range spindle. All of those M code macro script would be implemented like GerdS example with the exception of no input parameter. The range would be hard coded.
Steve
I'm curious how the "P" Value is read. I didn't know you could add a "P" value to a macro line.
The code that GerdS posted doesn't do anything when I test it. I'm just running the sim on my laptop.
Okay,
I noticed that GerdS had the "M" capitalized in the macro. I made it lower cased and it works now.
Still, What does the P Value do in macros, it can be read by the (hVars) on a macro line?
What other things do people use this for?
That line pulls the P word from the G code line. It will be hard to debug in the editor since you can't really execute a G code line. There are also these related functions available:
flag, rc = mc.mcCntlGetLocalVarFlag(number inst, number hVars, number varNumber) -- This one tels you if the G code word was set on the G code line. e.g. "M101 P1"
local flag
flag, rc = mc.mcCntlGetLocalVarFlag(inst, hVars, mc.SV_P) -- flag would equal 1 because P1 was specified on the G code line.
flag, rc = mc.mcCntlGetLocalVarFlag(inst, hVars, mc.SV_Q) -- flag would equal 0 because Q was specified on the G code line.
comment, rc = mc.mcCntlGetLocalComment(number inst, number hVars) -- retrieve the comment on the G code line that contains the M code.
As I said earlier, it is hard to debug these things because no G code line has been executed when debugging in the script editor. So I put in a little helper API function that will simulate it. :)
hVars, rc = mc.mcCntlCreateLocalVars(number inst, string gCodeLine)
It would be used in the function call stub like this:
-- The function call stub is only ever executed when in the editor debugging, so it is safe to leave this in for testing.
local hVars, rc
M101(hVars)
end
There are caveats to passung G code words to M codes. One is you can't use the M word as a variable. You can use a word more than once. And finally, the M code that takes variables has to be the only thing on the line.
Steve
