Mach Discussion => Mach4 General Discussion => Topic started by: wjansen1954 on July 23, 2017, 02:36:29 PM
Hay all.
In Mach4 is a separate videocard necassery??
Willem
Interference with parallel port step signal timing due to motherboard
video access is usually less for modern motherboards, and does not
matter at all unless you are running the legacy Darwin parallel port
driver. For any system running an Ethernet or USB connected
motion controller, video interference is not an issue.
Video performance can still matter. Mach4 uses Open GL video
drivers and needs reasonably good hardware. If you are running
G code files with megabytes of short segment movements such as
photo carving, you will need to have a couple of Gigabytes of
memory available for video, either motherboard or dedicated card.
Steve Stallings
www.PMDX.com
Thanks Steve
Just one more question:
What will happen if the memory is insufficient ?
Thanks again
The Open GL video data will page to disk and there is a dramatic impact
on screen update speed.
Steve Stallings
www.PMDX.com
Thanks for the explanation
Wllem
