G-Code, CAD, and CAM => LazyCam (Beta) => Topic started by: mcyr on June 23, 2007, 02:35:10 PM
Hi Art. When I loaded the attached dxf file into LazyCam (v 2.076 and 2.05) I found one of the entites distorted off the screen ("Before" screen capture). Cleaning did not help. However, I found that rotating it 90 degrees brought the entity back to where it belongs ("After" screen capture). Is there something in the dxf file causing this or is it in LaztCam? Thanks.
Best Regards,
Mike
I will have a look at your DXF... I think I know where the problem is :)
I tested it here and it is working ... I will update may code with Art and see if there is a bug in his Rev.
Brian
