Mach Discussion => General Mach Discussion => Topic started by: ozzey on June 27, 2017, 04:20:50 PM
Title: steppers nocking
Post by: ozzey on June 27, 2017, 04:20:50 PM
i have a new computor made of new parts (old stock ) i have it working but it has a nocking noise in the steppers it runs windows XP can anyone sergest any thing i can try to fix it
Title: Re: steppers nocking
Post by: joeaverage on June 27, 2017, 07:34:34 PM
how about some info? Parallel port or external controller? If parallel what kernel speed? If parallel what does
DriverTest.exe reveal? What 'steps per'? How many microsteps per step? What velocity and accel in motor tuning?
Can you post a Gcode sequence of moves that shows the fault?
Post by: RICH on June 28, 2017, 06:59:56 AM
Post the info requested in  reply #2.
The knocking sound you hear "may" be caused by a poor pulse signal coming from the parallel port / computer.
You would need to look at the signal with a o'scope to see it. My experience was "ringing"  on the pulse signal.
There is NOTHING you can do about it, conditioning, etc., etc. other than use an external motion controller.
Post by: ozzey on June 28, 2017, 07:20:45 AM
the old computer was working good its very old  need a back up CP for when it stops working so i know the mill set up is good on my mill must be the PC i have reinstaled XP  will try it tomorow im useing paralle port i used the XML file from old PC
Post by: reuelt on June 29, 2017, 03:01:56 AM
I think you need to turn off ACPI and convert the new XP installation to a STD PC with NON-ACPI HAL.
All new PCs are built with ACPI bios.
