Mach Discussion => General Mach Discussion => Topic started by: hophinhan on June 08, 2017, 10:12:49 AM
Title: HELP a newbie, so stress and depress...
Post by: hophinhan on June 08, 2017, 10:12:49 AM
I love OX CNC and built it. Bought electrical parts (including motors, board...) from a seller (who i now consider as mr. knowing nothing >,<)
It's a mach3 board
I'm using win7 32 bit
Please help, i did everything but still my PC won't communicate with CNC machine. The reset button wont stop blinking... nothing happens
Here are some pictures of my situation now... Please help, i'm so stress and depress now :(
Title: Re: HELP a newbie, so stress and depress...
Post by: kolias on June 08, 2017, 10:52:30 AM
Don’t be stressed / depressed, it takes time and patience to build a cnc but the rewards are immense
Your first picture looks like a BOB but I don’t see the printer port connection. Let us know how the wiring is done or a picture shown all the wiring
Post by: joeaverage on June 08, 2017, 07:41:08 PM
middle upper of BoB, next to relay, is that a USB socket?
Post by: hophinhan on June 08, 2017, 11:26:21 PM
Thanks you guys for replying :)
pls help me
here are some more wiring that the seller did for me, i just bring it home and plug it in
Before handed electrical parts to me, he did trial run and worked :(
Is it because of the windows 7 32 bit?
Post by: joeaverage on June 09, 2017, 02:09:11 AM
it is definitely a parallel port connected BoB with USb as a powersupply only.
I would suggest in the first instance disconnect all the stepper drives from the BoB. Concentrate on the Estop to start with, that will
establish communication with Mach, the start adding motors.
What port and pin is assigned to Estop?
Post by: kolias on June 09, 2017, 08:50:53 AM
You should consider arranging the wiring inside the control box in a better way. This kind of electronics are subject to “noise” and the way wires crossing / touching over drivers could create major problems
Post by: joeaverage on June 11, 2017, 01:24:51 AM
do you have a multimeter?  Disconnect all wires from your BoB except the power supply wires.
Suggest: Config/Ports and Pins/Input Signals  scan down to Estop, check Enable, Port=1, Pin=10, click Apply.
On Mach3 Diagnostics Tab is the Estop LED active or not? With your multimeter measure the voltage of pin 10 of your BoB
relative to 0V. If the voltage is high, 5V for a 5V BoB then your BoB has a pull-up resistor. In Machs default configuration, Estop
is active high, then I would expect the diagnostic Estop LED to be ON. If the voltage is low, 0V, then your BoB has a pull-down
resistor and I would expect the diagnostic Estop LED to be OFF.
Now: Config/Ports and Pins/Input Signals/Estop Enable=checked Port=1 Pin=10 Active Low=checked, Click Apply, I would expect with pin 10
voltage high then diagnostic Estop LED to be OFF. With Estop OFF you should be able to Reset Mach and have the Reset button go green and
be continuously light. If however pin 10 voltage is low, ie pull-down resistor, the diagnostic Estop LED should be ON. With Estop LED ON
no matter how hard you try you will not be able to Reset Mach, nor will you until you clear the emergency fault and get the Estop LED
to turn OFF.
If you now take a small wire from pin 10 to 0V, or alternately to 5V you should see the diagnostic Estop LED change state.
If you can follow this and get the Estop to work you've learnt about you BoB, that is, a pull-up or pull-down resistor and you've established
that your BoB can communicate over the parallel port. Thats good progress.
Let us know how you get on.
Post by: kolias on June 28, 2024, 02:15:16 PM
Hi, do you have a multimeter?  Disconnect all wires from your BoB except the power supply wires.
Suggest: Config/Ports and Pins/Input Signals  scan down to Estop, check Enable, Port=1, Pin=10, click Apply. On Mach3 Diagnostics Tab is the Estop LED active or not? With your multimeter measure the voltage of pin 10 of your BoB relative to 0V. If the voltage is high, 5V for a 5V BoB then your BoB has a pull-up resistor. In Machs default configuration, Estop is active high, then I would expect the diagnostic Estop LED to be ON. If the voltage is low, 0V, then your BoB has a pull-down resistor and I would expect the diagnostic Estop LED to be OFF....Craig
Hey Craig, I found this thread in my search to solve a similar problem. I have a Chinese BOB with 3 Relays and since the users guide is useless I try first to see how to connect the (NC) E-Stop. Between pins P10 and GND I have 2.5VDC when the E-Stop is pressed and 0 when not pressed. But pressing or not the E-Stop does nothing to Mach3. Is it because of the low voltage? If yes what is my options? Can I connect a 10VDC PSU and to where?
Many thanks
Nicolas
Post by: Oliver Matthews on July 15, 2024, 04:13:37 AM
This may be obvious to many, but if you are new you may not know.
You need to define the parallel port adress in Mach3 before it will communicate with the board.
This is a hex number and is usually 378H, though it can vary depending on your motherboard.
Until this step is complete, mach will be unable to recognise your controller or communicate with it.
Easy step to forget in the age of Universal Serial Busses that configure themselves.
Hope this helps.
Post by: kolias on July 15, 2024, 09:12:29 AM
Thanks Oliver, the problem was that i was using Mach3 inside an Oracle VirtualBox and as I understand VirtualBox does not support parallel port. I moved Mach3 in Windows10 PRO and I bought a UC100 motion controller which should arrive this week.
Nicolas
