Mach Discussion => General Mach Discussion => Topic started by: Chuckcoe on May 10, 2017, 01:17:45 PM
Title: Mach 3 and gwizard editor
Post by: Chuckcoe on May 10, 2017, 01:17:45 PM
I am looking at gwizard editor and when I load gcode I get an error " spindle not spinning "
My spindle is manually controlled and I don't know where change or how to correct problem.
Will not let me load to Mach3
Any suggestions
Title: Re: Mach 3 and gwizard editor
Post by: RICH on May 14, 2017, 06:48:00 AM
There are three M codes for the spindle.
M3/4 turns on the spindle cw / ccw
M5 turns the spindle off
Try just adding  M3 or M4 to the gcode and see if that works.
 Know nothing about the  UC100 so may want to read the manual about turning the spindle on / off even though
you are doing it manually.
Post by: ger21 on May 14, 2017, 08:51:05 AM
What's giving you the error? G Wizard?
If so, there must be setting in G Wizard to disable that warning.
