Mach Discussion => Mach4 General Discussion => Topic started by: Mauri on May 01, 2017, 05:41:35 PM
Title: Buffer Error Controller and Mach4 Out of Sequence
Post by: Mauri on May 01, 2017, 05:41:35 PM
Has anyone had Buffer Errors with Mach4 and Controller getting out of sequence causing Mach4 to go into an E-Stop condition?
If you continue from this point by Enable again Re-Start, it will run a further 50 to 100 lines of G-Code and then the same error occurs and goes into E-Stop (I have done this multiple times with the same result).
Only way to get out of it is a restart of Mach4 and Controller.
I have 200 Lines Look ahead in Mach4 is this too much?
Mauri.
