Mach Discussion => General Mach Discussion => Topic started by: rockyrude on April 19, 2017, 02:41:21 PM
Is it possible for Mach3 (full version) to report estimated run time for a file?
Yes, on the Toolpath Tab(alt 4) there is a button labled 'Simulate program run' which will simulate the loaded gcode and report the estimated time below. Not exactly accurate but close.
HTH
RT
Thanks for the info.
Is there a similar function in mach3 turn?
Not in the stock screens. You would have to use a screen editor like MachScreen to add the button and dro Both Standard Code 15. there may be a commercial turn set that has it but i have never looked.
HTH
RT
