Mach Discussion => General Mach Discussion => Topic started by: kharrisonkevin on April 19, 2017, 07:32:10 AM
Hi all. I am having trouble milling a hole. I have my cad gcode cutting a 1 inch diameter hole but it keeps turning out under size. I mic Ed my bit and put that in my tool size and my axis are all set to .Ooo5 accuracy. What is my problem. Or why.
It could be tool flex or machine flex - are you using G41 / G42 ?
Compare the results from one hole cut clockwise and one hole cut counterclockwise - is there a difference in dimension ?
No I am not using G41/42
There are number things that affect the accuracy.
How accurate do want want the 1" hole to come out?
1. What are you steps per unit for the axes?
Say it's 20000, then best possible resolution would
be 0.0005". Also the axis needs to calibrated correctly.
2. How accurate is your machine in both axis when actualy
moved at the location where the 1" hole is done?
? Any backlash, don't say none, it's just a matter of degree!
3. How did you measure the diameter of the tool?
I use V anvil mic's as they are accurate and made for that purpose.
4. How much run out do you have at the end of the mill?
5. How is the coding done? ie; mltiple cuts, spring passes,
etc.
If everything was perfect and the code was correct then the hole would be correct, BUT , that is not the case in the real world.
BTW,
If the hole comes out under then in cam you can just change / adjust the tool diameter ( same tool ) as the machine knows no difference!
As far as I know (a new by) my axis are set to at least 2000 steps per. I have my backlash is close about .001 or a bit less.
I measured the cutter with a mic (1/4 inch tool) measured .238 dia.
I have no idea how to measure the run-out
Use an indicator , preferably one that can measure to 0.0001", to measure the total run out.
Put a ground rod, drill blank, etc into the collet / chuck, rotate the chuck manually,
Measure both very near the collet / chuck and also at a distance approx. where the cutting edge of the end mill would be.
Do a few tests with your machine.
Mill a hole through some scrap for say a 1" dia hole doing a rough cut, a finish cut, and a spring cut in the kind of material you want an accurate hole to be milled. Measure the hole. If it's under than change diameter of the end mill to something smaller in the wizard / cam and do it again. Say your under by .004" then change the end mill diameter down by .002" or half what it is under.
That gives you a practical idea of how good the system is how to adjust for YOUR machine.
Easier would be to do the hole with code based on the center line of the hole and start point of the first move from the same location.
That takes into account everything. You have what you have, just need to consider what you can do with it and how to adjust to get what you want.
Thanks for the help. I will try what you said and let you know how I make out.
What I found with some of the holes is that they were slightly oblong. The x&y was about.012 undersized but at the 2-8 o'clock measurement was perfect. But I will try what you suggested I know I have run-out as I have a router for a spindle.
I haven't been able to measure for run-out as of yet but should it not cut undersize on the complete hole? I can understand that if the run-out is say .010 than the hole should turn out to be .020 under. Is this correct?
I am curious, can you post a picture of your cnc machine.
I'm not real happy with this machine I would like to rebuild it with a 12' Gantry and that will let me access through the side of the machine instead of the end or going under the ways on the y axis. Rich my picture is too big for this site and I can't zip the pic . Can you please send me your email address and I will send it that way. Thanks.
Forget about the picture.
So your using a router machine to "mill" and just let me say that
you probably do not have the rigidity of a milling machine.
Don't expect milling machine tolerances. The whole "system"
as applied to the machining task comes into play and is also dependant on the material your working with. So I will repeat "YOU have what YOU have" and it will only do what it can.
So do some testing both in the material you are working with, how the code is done, tool used, etc and see what it can do.
If you want better than what it can currently do then you need to look at each part of the system for possible improvement.
It must be too much flex in the z axis. I'm just machining wood not metals. When I rebuild it I'm going to use all steel. Thanks for all your help Kevin
I think that I just found must of the trouble. The y axis rail when the guy put it on was out by 1/8" and wanting to make the machine make very small jumps not visible to the eye. But when watching the vac hose you could see it make small shakes in the middle of the ways.. I ground the high spots out to straighten . I got the machine to Mill a 1" holein aluminum accurate to.004. Close enough for doing wood. Just thought I would share my findings it might help someone else.
