Mach Discussion => Mach4 General Discussion => Topic started by: jtiedeman on April 13, 2017, 05:02:39 PM
I have made a large tube plasma system (40' long, up to 10" diameter with 3/8 wall thickness ;D) and do a lot of cutoffs with it. I have a certain program that does a lot of incremental cuts in the Y axis so at the end of the program I want to re-home the y axis (it homes in place). I don't want to just zero the work offset because I use multiple work offsets. If I don't home it before the next tube it wants to completely unwind the y axis to start the next program from Y0. I am trying to use an M code to home my Y axis and it works great when I run it from the script editor but I can't seem to get it to do anything when I run it in MDI with an m code. Is there something I am missing or doing wrong here?
function m101()
inst=mc.mcGetInstance()
mc.mcAxisHome(inst,1)
end
if (mc.mcInEditor() == 1) then
m101()
end
I have a button to home the Y axis that works great, I am just trying to save some extra mouse clicks between tubes. Any help would be great. Thanks!
Joel
Mach4 core will not allow you to home from an mcode,
DazTheGas
Oh, that would explain why nothing I try works. I've got some ideas to change the program and work around it.
Thanks for the reply!
Joel
