Mach Discussion => General Mach Discussion => Topic started by: CNCDK on April 08, 2017, 10:49:55 AM
Title: New Feed Hold button
Post by: CNCDK on April 08, 2017, 10:49:55 AM
How I made so I can use an input to "Feed Hold" ??
I have input available on my bob (P13)
Title: Re: New Feed Hold button
Post by: olf20 on April 09, 2017, 07:03:48 AM
Goto config - inputs
Scroll down to oem#1
Assign correct port / pin
Then goto config - system hotkeys
Assign feedhold number from Hoods list above.
The number is in the 1000's
Save
Run
olf20 / Bob
Post by: CNCDK on April 15, 2017, 04:02:30 PM
Hi
can you describe in a better way how I do after this ??
Save
Run
Post by: olf20 on April 15, 2017, 06:35:27 PM
If you look at page 8 of Hoods OEM CODE List.
Open it with a spreadsheet program.
Scroll down to the 1000's and you
will see 1001 is PAUSE or feedhold.
This is the number you enter for the OEM Code #1
on the right hand side under System Hot Keys.
Of course you have to assign your port and pin
number to INPUT #1, under Configure, Ports & Pins,
Inputs.
Hope this helps. It is a little confusing and I may have
not explained it the right way.
Post back if you get hung up.
olf20 / Bob
Post by: CNCDK on May 09, 2017, 05:37:09 PM
1000 thanks
