Mach Discussion => General Mach Discussion => Topic started by: weyepx on April 08, 2017, 10:25:48 AM
I can't get the software to communicate to the Breakout board and work the machine.
I used software from Planet-CNC and it will work using USB from PC to the Breakout board (BOB).
I want to use MACH3, but can't get either a USB or DB25 serial port connector to work.
Using Windows 7-32 bit.
Software and driver test successful.
Using keyboard with MACH3, successful.
Communicate and operate through the BOB, unsuccessful.
Any and all help is appreciated.
Which software does not communicate with the BOB? What kind BOB you have? What kind PC you have?
