Mach Discussion => VB and the development of wizards => Topic started by: Tarak on April 04, 2017, 08:41:57 PM
Hi All,
I have an interesting probing issue that I am unsure how to easily overcome, I have programmed two buttons for testing purposes:
the first button is my step grinding program, it works a treat. ::)
I have used the following code style in both buttons:
OpenTeachFile "Step grinding program.cnc"
Code "(Step grinding program.cnc)"
STEP GRINDING PROGRAM GOES HERE
CloseTeachFile
Call LoadTeachFile()
the second is a probing routing which is an entire G code program I have written, it works quite well.
OpenTeachFile "probing cycle.cnc"
Code "(probing cycle.cnc)"
PROBING CYCLE GOES HERE
CloseTeachFile
I was originally hoping to run the program by putting it into an M code, but I now realise I cannot run it like this, the values would not update.
So I guess my questions are: ???
- How can I have it run the probing cycle during the STEP GRINDING PROGRAM which will measure existing step lengths.
- When I press the load button on the STEP GRINDING PROGRAM it loads all parameters from DRO's, so after running the PROBING CYCLE, how do I get it to load these new measured values into an already running G code program (STEP GRINDING PROGRAM).
Tarak ;D
