Third party software and hardware support forums. => PoKeys => Topic started by: ELCouz on April 01, 2017, 10:56:09 AM
Title: Pokeys57cnc Spindle Questions
Post by: ELCouz on April 01, 2017, 10:56:09 AM
Pokeys57cnc is a great product but I am having trouble to configure the spindle.
I am using mach4-hobby demo for now.
I configured my VFD (Chinese Nowforever D100) to work on 0-10V analog input for frequency adjustment. This is connected to PIN17 with PWM enable @ 10kHz like NeoTO recommended on an earlier topic.
The drive need a spindle enable signal to make it turn (Forward in this case). This is active low signal. I connected the VFD COMMON to OC4- and VFD X1 to OC4+. Is that right?
How I can make Mach4 to send active low signal on M3 with this OC4? I can't find what PIN number is OC4 neither on internet or the Pokeys Manual.
Arrrggg not clear!!!
(http://msn.elcouz.net/pins.png)
Thanks!
Laurent
Title: Re: Pokeys57cnc Spindle Questions
Post by: ELCouz on April 02, 2017, 09:50:35 AM
Just want to make the topic answered for future reference.
From Technical support:
The OC outputs are part of the 'Pulse engine' and you will find them under 'PoKeys PE' device in Mach4 IO mapping (read more here: http://blog.poscope.com/pokeys57cnc-pinout-explained/).
Hope this help in the future!
Thanks all!
Laurent
(http://msn.elcouz.net/pulseengine.png)
Post by: Lefty469 on July 10, 2017, 12:29:48 PM
Thanks all!
Laurent
Thank you!
