Third party software and hardware support forums. => CS-Lab => Topic started by: slovenec on March 31, 2017, 11:37:20 AM
Greetings altogether. My problem is so simple and yet I tried everything and no solution.
My linear scales are from ISKRA and they are 5um and this is 0.005mm (the seller told me that they are 0.5Um and now I found out they are 5um)
Anyhow, I have to set two parameters one is in the section Mach3-Config-Motortunning-Steps per unit.
Ok I contacted the Support after a month of trying different calculations and numbers and the answer was:
If you use a scale then you take neither ratio nor screw pitch into account.
Your task is to indicate pulses number per 1mm and the scale will help you with it.
>>> The resolution of linear scales is: 5µm this is 0.005mm
It's very easy:
1mm / 0.005mm = 200 steps per
Ok and now what is the Encoder Pulses/Rev: ( mach3-config-config plugins-CSMIO motion controller configuration)
Does anybody know please help. ???
Best regards
