Support => Forum suggestions and report forum problems. => Topic started by: jkcab on March 28, 2017, 01:04:30 PM
Why can't I post in the pokeys forum? I have tried several times over the last few days and get the same message each time. Mach support is not working and unable to fill your request HTTP error 500.
Please advise as to how I can post,
Jeff
Hi Jeff,
I just posted a test message in the Pokeys section without any problem.
Use the New Topic button to post.
I did use the new topic button. Every time i went to post. If you use the same subject it tells you that you already posted even though I had gotten the error message. Or if you use the same attachment it says you already downloaded it and you need to rename it. I tried 9 times. This morning I tried to look at this post and it said the site was down?
I will make another attempt.
Jeff
