Third party software and hardware support forums. => HiCON Motion Controller => Topic started by: Cbyrdtopper on March 03, 2017, 08:57:53 AM
When I use the reference all home button, It will home X,Y,Z, and A great but then it disables Mach4 and then my axis are dereferenced. How can I make make the Disable not dereference the axis?
Hello,
There is a setting for each motor in the plugin config (somewhere to the upper right of the window) with a checkbox to dereference an axis on disarm, or not.
-Marc Lim
Vital System Inc.
Hey Marc,
Thanks for the reply! My screen is oriented in Portrait, and for some reason it cuts off some of the Hicon Plugin Config window, however, I could read "Dere..." on the right side of my screen, so I unchecked that box assuming that was it and it worked. Now Mach is behaving almost how I want it to. It still dereferences the Axis when I use the Ref All button, but when I just home them individually it keeps them referenced when I Toggle Mach enable state. This I can live with no problem!!
Thanks for the help!
