Mach Discussion => General Mach Discussion => Topic started by: davethefixer on February 14, 2017, 10:56:26 AM
Hi all
im sure iv had this before but can not remember what the answer is.
i have copied a profile (as i wanted to up the z axis speed)
but when i then run that profile none of the homing buttons work
everything else seems to be fine the axis's move limit switches all ok all the settings seem to have copied but unable to home !!!!
Please tell me what iv forgotten to do to make this work.
thanks in advance guys
Are you using a custom screen?
Thanks Gerry
sorted now
I was using 2010 screen set and eventually remembered that you have to manually copy some of the macros "for some reason"
Thanks for the memory jog ;)
