Mach Discussion => VB and the development of wizards => Topic started by: glacier on June 13, 2007, 03:53:38 AM
I purchased a copy of mach3. I have several questions now.
for example: How to use M6start.m1s, which is under directory
C:\mach3\macros\mach3mill\
I have write M6start in G-code program instead of M6. The running stopped at the line
of M6start, and showed there's error.
Can anyone provide a demonstration, or tell me how to make a macro program that
when G-code program go to M6 ( or any other M command) function as below will be done:
1.spindle motor move to reference point?coordinates +110mm
2.set output#1 to 1
3. read input#3, if it's 0,wait; if it's 1, go next
4. set output#1 to 0
output#2 to 1
5.z-axis move to reference point?coordinates +210mm
6.set output#2 to 0
7.end
then G-code program goto the next line.
this is not complete but it give you some idea as to how it needs to be :-
M6.m1s
G53 Z110. M5
Activatesignal(output1)
if isactive(input2) then
'do something
else
' do something else
end if
deactivatesignal(output1)
G53 Z210.
Graham.
I believe the M6 is an internal Mcode that Mach uses to CALL the M6start macro. THe M6start macro is used to build a script to do a function such as run the Auto tool changer,ETC. "IF" you need the function, then"You" have to complete the M6start macro to YOUR specification.
Ya know i was all happy with my tool change macro. Then i ran a G21 program and ka boom. Some days it just doesn't pay.
I give up and i'm going to get my boat and hope it doesn't know any g, m, or vb codes.
When i get back i'll start working on a if then statement
Wes
