Mach Discussion => General Mach Discussion => Topic started by: DRivest on January 23, 2017, 02:19:30 PM
Hello all
Started my CNC the other day after a few years of "rest". I started with a simple sign using the WRITE Wizard and i got a problem i know I had a few years ago. The G-Code looks OK but when I run it the router stops even if it shows on screen that its moving. This happens for a single line but as you can imagine it trows off the whole job. Can you point me to where I should look?
Dom
Is the stepper motor for the axis that has quit moving making a whining noise ?
