Mach Discussion => General Mach Discussion => Topic started by: ozzey on January 12, 2017, 02:09:48 PM
i am geting error radius to end of ark differs from radius to start if i restart mack 3 it works again sum thing is turning it off any idear what it could be
It is caused by your IJ Mode being incorrectly set (Config. / General Config.).
Ideally all Gcode containing arcs should contain the G90.1 or G91.1 as appropriate - then the problem does not occur.
thank you i will fix it
