Third party software and hardware support forums. => Modbus => Topic started by: PtD on January 05, 2017, 03:58:18 PM
Title: TCP Modbus doesn't refresh holding registers?
Post by: PtD on January 05, 2017, 03:58:18 PM
I have set up an Arduino as TCP Modbus slave, and I have programmed it to increase the value of the holding registers every 2 seconds. I can connect to it just fine, I get the registers read and all seems perfect... Except that Mach3 only reads the up-to-date value of the holding registers only when I press "Apply" in the "Setup TCP Modbus" dialog. I have a brain that writes these values in user DROs, and the DROs have the values from the moment of pressing "Apply", they never change, unless I open the setup dialog and press "Apply" again.
In the TCP Modbus test dialog the values are updated every time when I press "Read".
Is this the expected behavior, or I'm missing something?
Mach3 version is R3.043.066, I am a licensed user. Configuration screens are attached below.
Thanks in advance.
