General CNC Chat => Share Your GCode => Topic started by: swassell on December 30, 2016, 09:52:45 AM
Thought I would share the G code for my Can't Fix Stupid wrench. It is made with 3/4" plywood. Also see the link below for a video on the making of it. Enjoy.
https://www.youtube.com/watch?v=WK524IH1saY
;D Thanks for sharing ;D
what is the board size and where did you "o" at? center lower left.
It is 3/4" Plywood and the final dimension is 6" x 32.5". The origin is at the lower left. If you want the CamBam file see attached. It has been zipped.
-Steve
thanks for the reply. can't use the file tho. I have BoB-Cad and use Fanuc G-Code. i'll getter done tho. :)
I don't know what I was thinking. I did run your code in Mach 3 and all is well. I just drew it out in Bob-Cad as dxf so the size could be tweaked. thanks.
Don't forget that if you want to change the scale of the Gcode you can just use the scale DROs in Mach3. To double the size of the Gcode you just enter 2 in both the X and Y DROs.
Mike
thanks for the reply. I used that function once but I needed it (DXF) so I could bring it down some. my machine max is only Y-20 X-40.
THIS IS THE DXF I MADE FOR CAN'T FIX STUPID.
