Mach Discussion => General Mach Discussion => Topic started by: jammyatter on December 27, 2016, 09:52:46 AM
Title: Setting up chinese cnc router
Post by: jammyatter on December 27, 2016, 09:52:46 AM
Im totally new to this so plz be patient
I bought one from ebay . Followed artsoft instructions as best i can and i dont think the pc and control box are communicating . In using itel celeron 2.4ghz pc with xp pro sp3
Driver check says excellent but axis motor wont move
Any ideas ? Thanks in advance
Title: Re: Setting up chinese cnc router
Post by: RICH on December 27, 2016, 06:26:37 PM
Have you contacted the seller about your problem?
Are you using a licensed version of MACH?
Have a good read of the Mach manuals and also watch the Mach vidoes.
Post by: GeoffW1 on December 29, 2016, 05:10:37 AM
Have a look to see the parallel port is enabled in XP, and that the parallel port address in XP is the same as in Mach3, Config Menu - Ports & Pins - Port Setup (you would usually be using Port 1). See here
http://www.radiosky.com/skypipehelp/V2/parallel_port_configuration.html
http://www.machsupport.com/forum/index.php/topic,14910.0.html
http://www.sevenforums.com/hardware-devices/344035-i-o-address-parallel-lpt-port-missing-resource-tab.html
Post by: jammyatter on December 29, 2016, 03:26:04 PM
Cheers for the help lads its up and workin . Thnk problem may have been windows wasnt 32 bit . Mach 3was version supplied
Lookin fwd to gettin some stuff done now
 Cheers again
