Mach Discussion => Mach4 General Discussion => Topic started by: Andy Higham on December 25, 2016, 03:30:07 PM
I set up my mill with smoothstepper latest plug is (188) and mach4 (2.0.3233).
I have set all the inputs and outputs in the plug in and in mach4. The spindle runs and I can control the speed, I can move all the axis using the jog buttons on the screen.
However when I go to the motors tab to set the speed/acceleration/deceleration and steps per unit all the boxes are greyed out, I cannot enter any values.
Is this because I have not yet purchased a licence? demo mode
The motor boxes normaly are greyed out until you select a motor.
DazTheGas
Disable Mach4 then go to motor page then move mouse to motor0 then click and you will see parameter and will be able to make changes.
