Mach Discussion => General Mach Discussion => Topic started by: Ussca on December 07, 2016, 11:18:42 PM
Title: Elapse time stops?
Post by: Ussca on December 07, 2016, 11:18:42 PM
Probably silly question but I have some programs that run fine but the elapse timer stops at a certain point every time. Is there some way I can keep it running?? TIA....
Title: Re: Elapse time stops?
Post by: Tweakie.CNC on December 08, 2016, 05:30:27 AM
I experience exactly the same issue - sorry but I am not aware of any resolution to the problem.
Post by: Ussca on December 13, 2016, 05:27:30 PM
I got it to work today. On one of those programs that stopped at 1:39. Probably something I clicked and didn't know but here is the fix. While program was running, I clicked on the window with the timer in it, it changed color shade a little and counted thru the entire run! Working fine now. Since I was not the only one experiencing this, I am sure there are more than just the one other that posted? So tweakie, give that a try and see if it works for you?.............
Post by: Tweakie.CNC on December 14, 2016, 12:45:04 AM
Thanks, I will give it a try.
