G-Code, CAD, and CAM => G-Code, CAD, and CAM discussions => Topic started by: vmax549 on June 05, 2007, 10:20:40 AM
DOes anyone know of a utility to strip out all the line numbers and then reinsert the line numbers in proper order???
After assembling several blocks of saved code the line number are all out of wack it would be nice to reassign all the line numbers after I have finished creating the code project. Hand editing is out of the question for the most part with the total number of lines of code.
Give me a day or two and I will add it to the G-Code scaling program.
Graham.
Thanks Graham, you da man. ;D
Good Morning Graham, did you ever get a chance to work on the gcode renumbering utility??
Thanks (;-) TP
Its on my list of to do's, maybe next week.
Graham.
Discriminator from http://www.cncedit.com
Will do that plus a lot more.
It's also a good back plotter so you can see the code it's cutting.
The download is free and un-crippled but lacks a couple of features that the paid version has but it doesn't cripple the program for normal work.
Well worth a look and it's saved my bacon on a couple of jobs.
John S.
