Mach Discussion => Mach Screens => Topic started by: ScrappyScooter on June 04, 2007, 12:25:36 PM
On the Program Run screen, the button script for the "Ref All Home" button has a syntax of 'DoButton (22)' etc...
Where can I find a list of all the 'DoButtons' ?
Check the Wiki is has the total list you just grab the OEM number, but here is a list that I have aready, sorry about all the code inbetween, I'm to lazy to remove i and just have the button code ;D but if you look at the list you'll see the name of the function and the DOOEMButton(*********)
Remeber there is two ways of doing buttons DoOEMButton or DOButton so if the number you found in the wikki isn't working than try the other sntax to call on a button.
I'd do your robot with a Flash screen, there is alot more you can do...let me know if you need any help.
http://www.artsoftcontrols.com/MachCustomizeWiki/index.php?title=Main_Page
Decleare Audio(has to be along side each code) Example:
Public Declare Function sndPlaySound Lib "winmm.dll" Alias "sndPlaySoundA" _
(ByVal lpszSoundName As String, ByVal uFlags As Long) As Long
sndPlaySound "Bitmaps\Machwave\MaleVoice\LoadGCode.wav", &H1
DoOEMButton (216)
--------------------------Start of Code-------------------------------------------------------
-----------------------------------------------------------------------------Estop:
sndPlaySound "C:\WINDOWS\Media\Machwave\ResetSwitch.wav", &H1
DoButton (21)
-------------------------------------------------------------------------OFFLINE ON LINE:
value = GetVar(1)
If value= 1 Then
Call SetVar(1, 0)
DoOEMButton(178)
sndPlaySound "C:\WINDOWS\Media\Machwave\Online.wav", &H1
Else
Call SetVar(1, 1)
DoOEMButton(178)
sndPlaySound "C:\WINDOWS\Media\Machwave\Offline.wav", &H1
End If
------------------------------------------------------------------------REFER HOME
DoButton( 24 )
sndPlaySound "C:\WINDOWS\Media\Machwave\Homing.wav", &H1
DoButton( 23 )
DoButton( 22 )
DoButton( 25 )
-------------------------------------------------------------------------LOAD GCODE
sndPlaySound "C:\WINDOWS\Media\Machwave\LoadGCode", &H1
DoOEMButton (216)
---------------------------------------------------------------------------------Close GCODE
sndPlaySound "C:\WINDOWS\Media\Machwave\CloseGCode", &H1
DoOEMButton (169)
-----------------------------------------------------------------------------------Edit GCODE
sndPlaySound "C:\WINDOWS\Media\Machwave\EditGcode.wav", &H1
DoOEMButton (115)
--------------------------------------------------------------------------------START PROGRAM
sndPlaySound "C:\WINDOWS\Media\Machwave\Play.wav", &H1
DoButton (0)
--------------------------------------------------------------------------------STOP PROGRAM
sndPlaySound "C:\WINDOWS\Media\Machwave\Stop.wav", &H1
DoButton (3)
---------------------------------------------------------------------------------REWIND
sndPlaySound "C:\WINDOWS\MEDIA\Machwave\Rew.wav", &H1
DoButton (2)
--------------------------------------------------------------------------------HOLD PROGRAM
sndPlaySound "C:\WINDOWS\MEDIA\Machwave\Hold.wav", &H1
DoButton (1)
------------------------------------------------------------------------------REGEN
value = GetParam("Boundry")
If value = 1 Then
'SetButtonText " Job "
SetParam "Boundry" , 0
sndPlaySound "C:\WINDOWS\Media\Machwave\JobDisplay.wav", &H1
Else
SetParam "Boundry" , 1
'SetButtonText "Machine"
sndPlaySound "C:\WINDOWS\Media\Machwave\TableDisplay", &H1
End If
-----------------------------------------------------------------------------------CHANGE PAGE
sndPlaySound "C:\WINDOWS\Media\Machwave\ClicksoundScreen 2.wav", &H1
DoOEMButton (1)
----------------------------------------------------------------------------------ZERO ALL AXIS
sndPlaySound "C:\WINDOWS\Media\Machwave\ZeroAllAxis.wav", &H1
DoButton (8)
DoButton (9)
DoButton (10)
-------------------------------------------------------------------MACHINE/SOFTWEAR POSITIONING
value = GetVar(1)
If value= 1 Then
Call SetVar(1, 0)
DoOEMButton(256)
sndPlaySound "C:\WINDOWS\Media\Machwave\MachineCoordinetsOn.wav", &H1
Else
Call SetVar(1, 1)
DoOEMButton(256)
sndPlaySound "C:\WINDOWS\Media\Machwave\MachineCoordinetsOff.wav", &H1
End If
------------------------------------------------------------------------------JOG MODE
DoOEMButton (245)
-----------------------------------------------------------------LAUCH PROGRA< (ONSCREEN KEYBOARD)
sndPlaySound "C:\WINDOWS\Media\Machwave\LaunchKeyboard.wav", &H1
Dim stAppName As String
Dim filePath As String
stAppName = "C:\Program Files\Click-N-Type\Click-N-Type.exe"
Call Shell(stAppName,1)
---------------------------------------------------------------------------------JOG ON/OFF
value = GetVar(1)
If value= 1 Then
Call SetVar(1, 0)
DoOEMButton(103)
sndPlaySound "C:\WINDOWS\Media\Machwave\JogModeOff.wav", &H1
Else
Call SetVar(1, 1)
DoOEMButton(103)
sndPlaySound "C:\WINDOWS\Media\Machwave\JogModeOn.wav", &H1
End If
----------------------------------------------------------------------------------INCREASE FEED
sndPlaySound "C:\WINDOWS\Media\Machwave\FeedMore.wav", &H1
DoOEMButton (108)
------------------------------------------------------------------------------------DECREASE FEED
sndPlaySound "C:\WINDOWS\Media\Machwave\FeedLess.wav", &H1
DoOEMButton (109)
-------------------------------------------------------------------------------------SOFTLIMITS
value = GetVar(1)
If value= 1 Then
Call SetVar(1, 0)
DoOEMButton(119)
sndPlaySound "C:\WINDOWS\Media\Machwave\SoftwearLimitsOff.wav", &H1
Else
Call SetVar(1, 1)
DoOEMButton(119)
sndPlaySound "C:\WINDOWS\Media\Machwave\SoftwearLimitsOn.wav", &H1
End If
------------------------------------------------------------------------------RAPID ACTIVE/DEACTIVE
value = GetVar(1)
If value= 1 Then
Call SetVar(1, 0)
DoOEMButton(287)
sndPlaySound "C:\WINDOWS\Media\Machwave\RapidActive.wav", &H1
Else
Call SetVar(1, 1)
DoOEMButton(287)
sndPlaySound "C:\WINDOWS\Media\Machwave\RapidDeactivated.wav", &H1
End If
------------------------------------------------------------------------------AUTO LIMIT OVERRIDE
value = GetVar(1)
If value= 1 Then
Call SetVar(1, 0)
DoOEMButton(149)
sndPlaySound "C:\WINDOWS\Media\Machwave\AutoLimitOverRide.wav", &H1
Else
Call SetVar(1, 1)
DoOEMButton(149)
sndPlaySound "C:\WINDOWS\Media\Machwave\AutoLimitOverRideOff.wav", &H1
End If
---------------------------------------------------------------------------------TOOLCHANGER ON/OFF
value = GetVar(1)
If value= 1 Then
Call SetVar(1, 0)
DoOEMButton(168)
sndPlaySound "C:\WINDOWS\Media\Machwave\ToolChangedeActive.wav", &H1
Else
Call SetVar(1, 1)
DoOEMButton(168)
sndPlaySound "C:\WINDOWS\Media\Machwave\ToolChangeActive.wav", &H1
End If
--------------------------------------------------------------------------------MANUAL OVERRIDE
value = GetVar(1)
If value= 1 Then
Call SetVar(1, 0)
DoOEMButton(150)
sndPlaySound "C:\WINDOWS\Media\Machwave\ManualOverRide.wav", &H1
Else
Call SetVar(1, 1)
DoOEMButton(150)
sndPlaySound "C:\WINDOWS\Media\Machwave\ManualOverRideOff.wav", &H1
End If
-Check out http://AlphagraphicDesigns.com
for more Graphics and screens
