Mach Discussion => General Mach Discussion => Topic started by: Raychar on November 16, 2016, 07:45:55 AM
Hi, everbody,
The defined variable‘s value in the main program cannot pass down to subroutine program....
In main program, there are different cases to have different time values as below:
Sub main
Case 1.... t=1000.... call A
Case 2.....t=2000.....call A
End Sub
Sub A
ActivateSignal(Output4)
Sleep(t)
DeActivateSignal(Output4)
Sleep(50)
End Sub
However, during the program runs, corresponding t value cannot be read in subroutine, can anybody help to explain what mistakes were made?
https://www.google.co.uk/url?sa=t&source=web&rct=j&url=http://www.machsupport.com/wp-content/uploads/2013/02/VBScript_Commands.pdf&ved=0ahUKEwjS6bC-hq7QAhWmIsAKHaasAzcQFggaMAA&usg=AFQjCNFszAIBSvNbzrOHiGC9a9OX58NWWA&sig2=e_RcX9WV8c1DtHsAg3GPSw
Pdf page 11, need to pass the parameters in brackets and need to define the parameters for the sub
VB is not really my thing...
Thanks for the guild line. It works now as below:
Sub main
Case 1.... t=1000.... call A(1000)
Case 2.....t=2000.....call A(2000)
End Sub
Sub A(t As Integer)
Sleep(t)
Sleep(50)
End Sub
However, to go a step further, wanting to define the two variables at the beginning of program, it won't work..??
Sub main
Dim t1
Dim t2
t1=1000
t2=2000
Case 1.... t=1000.... call A(t1)
Case 2.....t=2000.....call A(t1)
End Sub
Sub A(t As Integer)
Sleep(t)
Sleep(50)
End Sub
Case 2.....t=2000.....call A(t1) should be Case 2.....t=2000.....call A(t2)....
Glad you found a solution, sorry couldn't be more help, but that's for reposting as I learnt something (been playing with c, c# for a while, VB requires a brain reboot)
