Mach Discussion => General Mach Discussion => Topic started by: aStranger on November 12, 2016, 06:39:00 AM
I know that I can use /p to select the profile I'm starting with
(thanks to this post https://www.machsupport.com/forum/index.php?topic=10421.0)
like for example:
> c:\mach3\mach3.exe /p smoothstepper
my question is, what other "parameters" are there?
is there somewhere i can find a "list" of them?
thanks for the trouble.
I have started a document to address your question to be inclusive of what has been posted over time on parameters.
That said,
I can create a thread so others can review it and comment and after updating put it into Members Doc's.
That said,
that would be great, thanks
Lets see how much interest there is and if others will contribute.
Attached for user comments.
Hey Rich, I may have misunderstood the original question and forgive me if I have, but I believe the OP was asking about command-line parameters to start the Mach3 program, not the g-code program itself. In the post, he gives the example:
This would start the program with a profile called "smoothstepper". Are there other command-line switches such as this? I'm curious to know about them as well.
That said, I love the document you've produced. It's very informative. I just wish I had the creativity to understand how I might use parameters in my code, but I am simply using a CAD program to create my g-code files.
Highspeed1964
I don't know.
That's why I have asked for comments. and also tried to define parameter and variable.
Not sure what the document will include in the end. It will not be a how to do on scripting.
I'll waite for user comments and go from there.
