Mach Discussion => General Mach Discussion => Topic started by: mismas on November 05, 2016, 11:49:55 AM
Title: Only partial toolpath after installing parallel driver....help :S
Post by: mismas on November 05, 2016, 11:49:55 AM
Hi Guys,
Hope somebody can help me with this. I searched the forum but didn't see any problem like mine...
I'm running demo mode of mach3. when i run it without the parallel driver installed mach3 works fine. g-code is loading and toolpath is generated perfectly. HOWEVER, as soon as i install the parallel driver and i load the same g-code the toolpath only shows a small section and when i scroll thru the g-code on program run page it seems to be "stuck" at random lines.
I assume this has nothing to do with it being demo version and more with a conflict? I have already tried another port address but this didnt help either....
anybody has an idea?. I ran out of ideas so any help is welcome!
cheers,
Mis.
Title: Re: Only partial toolpath after installing parallel driver....help :S
Post by: ger21 on November 05, 2016, 12:23:22 PM
No, it's a demo limitation, 500 lines of code is all it will display.
Post by: mismas on November 05, 2016, 12:37:41 PM
ah!!!...dumb me  ;D....I just purchased a license.
thanks.
