Mach Discussion => General Mach Discussion => Topic started by: ministeam on October 18, 2016, 02:07:57 PM
Hi
i have a problem with my denford orac cnc lathe that i hope the people on
this forum can help me solve this problem
the lathe was converted to mach 3 about 3 years ago and has been a very reliable machine
until easter sunday this year when it decided that it would no longer do external or internal
threads , but still works very on normal turning jobs
the machine is using mach 3 version 062
i have tried a new cnc4pc spindle index board but this has not solved my problem as well a
few other ideas found on internet , the latest being a proximinty switch which i bought from
cnc4you this gives a very stable spindle speed but still no threading .
the problem when threading it is not picking the pitchin the same every time so all it
ends up with is alot of grooves
i have changed to a new copy of mach 3 on about 6 times just in case the program is corrupted
but still no joy
i have been stuggling with this problem for 7 months and have now run out of idea's so please
can anybody help me
thank you
robert
Post your xml file that you are using.
A few questions:
Are you using steppers?
Are you sure that the spindle index is working / checked it?
How are you generating the threading code?
- Are you allowing for 3 to 5x pitch movement so the axis can accelerate?
- If using the wizard did you "calc the number of passes Button " to check if your velocity and accel is appropriate for the thread?
Try just scribing as a check to see how well it's following the pitch.
Again post your xml file.
Till Then,
rich
thank you for your reply
yes i am using stepper motors and using the parrallel port
i have checked the spindle index board with a meter and i am getting 5.08 volts when it sees the slot
and 0.8 when not seeing the slot , the disc has a single slot which is 20mm wide
the threads are done by hand coding
i always start any thread 15 mm from the front of the job
thank you
robert
Config menu then Ports and Pins then Spindle Setup, enable the Use Spindle Feedback in Sync mode option
Assume Hood already looked at your xml and found the problem. ;)
Note that a thin disc on the end of a shaft with the edges blackened in the spindle provides a surface to check repeatability
of the indexing during threading.
hi
thank you to rich and hood for help with trying to solve my problem , i will try both idea's tomorrow morning
when i go to my workshop
robert
hood
i altered my machine settings to 'spindle feedback in sync mode' when it came round to the threading cycle the machine moved to the starting position & didn't move any further
help please , have i got a corrupt version of the thread code , anybody got any idea's as to what is happening
all the best
robert
Threading ,the start of the Z motion, will not begin if the index pulse is not seen by Mach.
What is your Index Debounce value set to in configuration?
The debounce is defines how many times Mach must see the index before it accepts it if memory serves me.
I asked you to check / confirm the index was functional..........
(See page 9 of Threading On The Lathe - Mach 3 Turn write up which you will find in Members Doc's.)
rich
the index debouce is set to 10
i have checked the index signal with a meter , i am getting 5.08 volts working & 0.8 volts not working this at index pulse board
at the input pin connection i am getting the same voltage readings , i have also checked the parallel cable to make sure i haven't got a broken wire in the cable
if i tick the spindle speed averaging box i get threading movement but if i tick the use spindle feedback as well as the machine just hangs when it gets to the threading cycle
robert
As Rich says it would seem Mach is not seeing the index pulse clearly. Try Zero for the Index Debounce and see if that helps. If not, and if you have another spare input try and swap to that and see if it helps.
Just a thought but does the "Index" led flash on the diagnostics page when it sees the sensor input?
Go to diagnostics and see the condition of the index trigger LED per the ref given in the write up. In that condition the spindle is off.
The index board that you are using seems like it is working, BUT, the input must be seen by Mach.
BTW, I will be out and about for a few days ...... your in good hands with the other folks. :)
hi all
i have looked at the index pulse signal on the diagnostics page & it will flash about 6 times straight after each other & then it seems to miss about 3 flash's & then does the six flash's
the control board for the spindle index has an led on it that flash's with the pulses this seems to be flashing on every pulse signal
hood - i will try 0 on the debounce on sunday when i next go to my workshop , i have also tried the input in 2 diferent positions on the breakout board & still get the same results
thank you all for your replies
robert
hi
looks like i have found my problem ,does anybody know if there is a design for an index pulse board on here or the internet that will hopefully solve my problem or maybe a trade supplier that does a reliable item that works all posts will be answered
thank you
robert
looks like I have found my problem
What was the problem?
You don't need anything special.
Hood and myself have used the same and quoting Hood " an Optek OPB917B it has everything you need except for a limiting resistor for the LED, 220 Ohm is what I use when powering from 5V". Use just the opto on the Sherline lathe.
Some folks put and additional circuit after the opto to make sure the signal is a nice clean square wave.
I currently use a Halls effect sensor as it uses a small magnet for detection. It is not to cheap to buy, works great. and made for easy mounting on my Atlas lathe.
Just note that some types of sensors will not be work well ie; a reed switch may not sense quick enough for higher rpm readout. It depends on the device. So read the device specs.
hi rich
have you got a drawing i could have , i am not very good with electronics , i am a turner/fitter by trade
thank you
robert
Schematic attached.
hi rich
thank you for your sketch that will help me a lot
i ordered an optek opb017b this morning hopefully it will be delivered tomorrow morning thank you for all your help
robert
I hope it's correct. You should download the spec sheet from the Optek site.
Glad I could help.
BTW,
How many of those C3 boards did you go thru? 3 or so?
hi rich
i have 3 off c3 boards all with problems , i have even sent 2 of them to a friend who is an electronics engineer to see if he could repair them for me , he found cracked tracks on both & loose items on both boards that hadn't been soldered properly
all the best
robert
