Mach Discussion => Mach4 General Discussion => Topic started by: gorf23 on October 18, 2016, 12:28:37 PM
Title: Lua Debug/Editor Key board short cuts Problem
Post by: gorf23 on October 18, 2016, 12:28:37 PM
I have a script created it compiles OK But i want to step thought it, but the key board short cuts don't seem to work
I hit the F11 that should be a single step but i get nothing i get no response from any key board short cut, i have
to continually go to the drop down menu to make it step..
Is there a trick i am missing for the keyboard short cuts.
Thanks gary
Title: Re: Lua Debug/Editor Key board short cuts Problem
Post by: DazTheGas on October 18, 2016, 12:33:20 PM
If you have the keyboard plugin enabled try dissabling it in the taskbar.
DazTheGas
Post by: gorf23 on October 18, 2016, 05:44:02 PM
Tried disabling the keyboard plugin still no keyboard short cuts
then tried disabling a couple other plugins still no keyboard short cuts
Just doesn't want to work
Thanks gary
