Mach Discussion => General Mach Discussion => Topic started by: Graphicman on October 16, 2016, 05:57:28 PM
Title: Weird behavior even with the latest version of Mach3
Post by: Graphicman on October 16, 2016, 05:57:28 PM
Hello guys
I have just installed a 4th axis to my cnc machine
I noticed a very weird behavior with Mach3 that took me a while to figure out where it come from
I simply noticed that I can no longer see that white point/small line of the tool position on the path preview window!
I have not touched any general settings I used to have, just the necessary setting for the new A axis
After some investigation that even included a new installation I found out the the A axis must be on zero position not only that but it must be also on zero on the table position!!
I thought that is a bug and may be fixed in the latest version but I just found that it did not fix that!
It is very annoying as I am really used to use the tool position preview for different reasons
And it is very time consuming to make sure the a axis is always on zero position on both fixture and table position!!
Any ideas what is so wrong about that?!
