General CNC Chat => Building or Buying a Wood routing table.. Beginnners guide.. => Topic started by: Shelly on October 11, 2016, 01:18:37 AM
Hi, hopping someone has done this. I have a yoocnc parrellel port card on 6040 machine and want to wire this in to run newforever inverter
Using Mach3. There are 3 pins on the board, but don' t know whether these are opts isolated ? The can be configured to apply 0-10v signal to the inverter. any advise appreciated. :)
The 450 Kjb parallel port card has only a PWM pin 17.
The Nowforever need Analogue 0-10V.
So your need a converter like
http://www.dx.com/p/maitech-pwm-turn-0-10v-digital-to-analog-module-green-318473?tc=AUD&gclid=EAIaIQobChMIidH98ZL01AIVkQQqCh0AsA4xEAQYAyABEgLK4fD_BwE#.WV3o2cAy_cs
Once you have Analogue 0-10V, you connect Analogue ground and 0-10V to aGND and AN1 respectively. lower connection 1 and 3 from left on the Inverter.
You also need a pin that enables the PWM pin (probably Pin 1?) + digital ground. Top row connection 1 and 5
Only 4 wires.
At inverter console change
P0000 set to 1
P0002 set to 2
PWM pin 17 must be set to active low in Mach 3 otherwise you will have 10V (full speed) all the time.
PS: it might be cheaper to just change your BOB to a 5 axis BOB that includes Analogue 0-10V plus relay. Cost about $10
manual of a cheap 5 axis BOB with opto-isolation + 0-10V and a relay
www.hobbytronics.co.za/Content/external/473/5-axis%20manual.pdf
Nowforever VFD Manual: http://docdro.id/NYibeDM
Here is another link for the E100 VFD manual:
http://ri.search.yahoo.com/_ylt=A0LEVxHE9F1Zd0UAiQlXNyoA;_ylu=X3oDMTByZnU4cmNpBGNvbG8DYmYxBHBvcwM5BHZ0aWQDBHNlYwNzcg--/RV=2/RE=1499358532/RO=10/RU=http%3a%2f%2fblog.opilab.ch%2fcnc%2fNOWFOREVER%2520MANUAL%2520E-100.pdf/RK=0/RS=MhJEQwYF4wnkaxEL9_cCyiMyl3Y-
