Mach Discussion => General Mach Discussion => Topic started by: remo84 on May 30, 2007, 02:10:50 AM
my cnc is already works on mach2 on my computer but when i change the pc to another it doesn't work for the same config.
so i think that the problem is in bios config. for the parallel port so i make it exactly like that one who works put still not working.
so i reverse , i mean i begin to change the bios config. for parallel port on the pc which cnc was already work on it, i find that it works for all parallel port configuration . so i don't know what is the problem.
what do you get when you run the driver test? and on the diagnostics page there is a DRO for TIme In Int, What is the value in the DRO?
We will see if you have the driver and after that we will check the port.
Brian
