Mach Discussion => Mach Screens => Topic started by: MegaMoog on August 27, 2016, 09:00:52 PM
Title: PBJ 2013 Screenset
Post by: MegaMoog on August 27, 2016, 09:00:52 PM
Hi everybody, I have a situation with my machine / tool change functionality when using the PBJ 2013 Screenset. The machine will not make the moves required to start n finish the tool change when running G-code?
Using this screen set because of the 5-Axis functionality
Specs are as follows:
Windows XP SP3
Mach3 v R3.043.066
PBJ 2013 v1 screenset (All items loaded where they belong according to installation instructions)
My actions:
Power up machine
Home X Y Z B C axis
Set G54  X Y Z offset location
Tool Zero Z setting page (All locations set for tool change & switch position) (Using SINGLE OFFSET OPTION #1)
Press *Make Reference Height Button* (Z moves to safe Z height, X Y move to Tool Probe location n Z starts probing down, touches plate, Z returns to safe height and X Y returns to location before cycle started)
Load G code program with tool changes, Start program, 1st tool finishes, call T2 M6, and MACHINE JUST SITS THERE… Tool Change light FLASHING… but NO MOVEMENT toward safe Z or X Y tool change location???
I have tested following also on Tool Zero Z setting page:
Press *Start Tool Change/Tool Zero Button n all works as it should!!!
Z goes to safe Z height, X Y move to tool change Location, spindle stops, I change tool, press start, Z moves to safe Z height, X Y move to switch plate location, Z starts probing down n touches plate, Z retracts n X Y move to location where it came from b4 pressing tool change button!!!
I'm ASSUMING, I DO NOT have to switch from Program Run page to Tool Change page to make a Tool Change……
I thought the macros would do that for me, n I just manually change the tool?
Has any body else had this situation happen?
I tried contacting Per Jeppesen but no response yet…
Hope some one has some insight that can HELP!
MM
P.S. I have reloaded Mach3 and all my settings n profile along with items from PBJ screen set… still did not work…? ??? ??? ???
Title: Re: PBJ 2013 Screenset
Post by: ger21 on August 28, 2016, 01:30:11 AM
I don't know anything about this screenset,but you really shouldn't be using 3.043.066, as it's very buggy and causes issues for a lot of people.
Post by: MegaMoog on August 31, 2016, 07:57:41 PM
Thanks Gerry,
I tried .037 & .062 without any luck.
I'm assuming when an M6 is called out in the g-code it would start running tool change macro?
Wonder how I can test anything from here? I looked at macros M6 start n end but it all looks like a foreign language to me! Unless there is something else that should be triggering it?
Hopin someone has a working PBJ 2013 setup n check there macros n see if there the same as mine.
P Jeppesen did get back to me but couldn't see as to why its not working.
MM
