Third party software and hardware support forums. => CS-Lab => Topic started by: slovenec on August 15, 2016, 02:48:33 AM
Title: CSMIO MPG hadn wheel need help
Post by: slovenec on August 15, 2016, 02:48:33 AM
Greetings,
I have a question regarding the hand MPG. On eBay i found a MPG and now the seller has asked me which type do i need.
Type of the controller : HEDSS ISMM2080, you want 5V,12V or 24V, for the output circuit---it has 4 different modes:open collector NPN, Push PUll, Line driver, Voltage
It has to be : 5V TTL rotary encoder and power supply 24V  is there anything else that i must look for?
Best regards
 And thanks for any help!
Title: Re: CSMIO MPG hadn wheel need help
Post by: Hood on August 15, 2016, 05:08:46 AM
5v line driver is what you want, assuming you are connecting it via the MPG module.
If you do not have the MPG module then I don't think an MPG (Handwheel) can be used but to be certain you would have to check with CS-Lab.
Post by: slovenec on August 15, 2016, 06:05:39 AM
Hey hood.
Yes i have bought the module. Now the seller wanted to know wich one i would need.
Attached you will find the data sheet of the hand wheel
So i take the 5V output circuit and ttl signal ?
https://www.dropbox.com/sh/5zyu75x5e756ku1/AADZO8KOkRyX_a6qm7OCSv-pa?dl=0
Post by: Hood on August 15, 2016, 06:16:06 AM
The MPG unit needs 5v TTL so that is 5v line driver.
The switch/rotary switch  connections  on the MPG unit are 24v
The Potentiometers (Feed and Spindle Override pots) are 5v.
The MPG unit has both 24v and 5v power connections so the only ting you need to worry about is that the MPG (The handwheel itself) is 5v line driver.
