Third party software and hardware support forums. => Galil => Topic started by: chuk on August 15, 2016, 12:24:58 AM
Hi all, new to the forum. I'm 99.9% finished with a servo-actuated router build, and I'm hung up on the VFD spindle.
Controller: DMC-2140
VFD: Hitachi SJ200-2
Plugin: re-downloaded the non-SmartTerm version last week.
The spindle runs correctly using OFW, so I know the wiring is good, but I can't get Mach to generate voltage at MOCMDW.
Ports & Pins:
Spindle is Enabled, with everything else set to null.
Enable output is set to pin 41, and it responds as expected with a SH command (I'm fine with forward-only for now).
Spindle setup tab, Motor Control: Use Spindle Motor Output is checked. I'm not sure whether PWM or Step/Dir is more appropriate (neither is true in this case), but I have to choose one, and I've tried both with no luck.
Galil plugin:
Axis setup: A is mapped to W(D), configured as a servo (X, Y, and Z are mapped 1:1 as servos, and working beautifully).
Spindle is 0v to 10v is checked, Encoder is not.
Spindle Pulleys:
I set a 1:1 pulley at 1000rpm to be safe. Spindle runs at 24000rpm @ 400Hz
Motor tuning: Spindle:
Steps per is set to 60 (again, to be safe), and I've moved it around with no effect.
Is there anything that I'm missing..?
Figured it out. It was the axis mapping. Somehow I failed to notice the "S" in the Axis Mapping tab in the Galil plugin setup, so it was trying to send signals to a nonexistent A axis. S=Spindle, of course.
So the correct setup for my 3-axis servo router with a VFD-controlled spindle is:
Mach Axis -> Galil Axis
X:-> X(A) Servo Motor
Y:-> Y(B) Servo Motor
Z:-> Z(C) Servo Motor
S:-> W(D) Servo Motor
Seems simple enough, but after the 10000 other things that went into this build, I somehow missed that. Now I have a fully running machine!
