Mach Discussion => FAQs => Topic started by: jroberson on August 14, 2016, 03:51:02 PM
I needed to change the computer running mach3 USB ( R3.043.066) licensed. I downloaded same version on new HP computer ( Windows 10), configured ports & pins, but when I setup Motor Tuning, there was no blue lines. I selected X axis, when I imput veloc. and accel, they disappear if I touch slider bar. When I imput steps and touch slider bar, veloc and accel disappear...
I have looked at old settings and see no difference, even downloaded mach3 again. Motor outputs were the same.
I have not connected to cnc machine yet, but I was able to set up Mach3 before.
What am I missing?
JR
Which external motion controller are you using ?
I have a Mach3 USB motion controller MKX-IV, and I'm running Windows 10 on a new HP All in One.
Thanks for reply,
JR
Hi JR,
I guess something has gone wrong with your installation of Mach3.
Version .066 is probably not the best to be using (according to popular opinion) so I suggest you download version .062 then install that as administrator and see if that resolves the problem. Here is a direct link to the file ftp://ftp.machsupport.com/Mach3/Mach3Version3.043.062.exe (ftp://ftp.machsupport.com/Mach3/Mach3Version3.043.062.exe)
It should install directly over the top of your existing version but keep a safe copy of your license file (Mach1Lic.dat) and <your profile>.xml file just in case.
Tweakie,
I downloaded .062 version, but slider bar still not working... I took the new computer out to my workshop, connected to machine and I was able
to imput accel / veloc in Motor Tuning, and adjust slider bars... Whoo Hoo!
You da Man,
JR
Hey Guys,
After getting my Motor Tuning working, I realized my zero probe wasnt working ( after switching to new computer) Machine
kept going down when I tried to auto zero probe.
I was checking for complete circuit, but got no digitize light on trouble shooting page. I have checked ports and pin
imputs for probe, and have current through probe wires. I used same button script that got it going last time.
I remember Mach3 asked me which file to use for probe somewhere in button script or editor, but havent seen that yet?
Could use some help again,
JR
