Mach Discussion => Mach4 General Discussion => Topic started by: native34 on August 10, 2016, 06:06:47 PM
Title: Mach4 error comp calc failed with current tool radius
Post by: native34 on August 10, 2016, 06:06:47 PM
Can someone help me understand why I'm getting this error message in mach4? I'm trying to machine an outter contour, using the wear option in fusion 360. And as soon as I get to this option in mach4 it throws the above error.
Title: Re: Mach4 error comp calc failed with current tool radius
Post by: native34 on August 12, 2016, 02:28:20 PM
Any help please??
Post by: bob_at_pmdx on August 15, 2016, 04:55:18 PM
I'll admit up front that I know nothing about Mach4's implementation of tool cutting compensation.  But an obvious question would be what was the current tool radius when you got that error?
Post by: native34 on August 17, 2016, 07:14:29 PM
I've tried several versions of mach4 and I can't get the wear or control option to work. I can only get the in computer option to work. If I let the cam software choose the tool path everything work but when I output a g41/42 mach4 does not run.
Post by: smurph on August 17, 2016, 10:51:26 PM
Post up some code that fails.  I was running some cutter comp stuff the other day and all was fine.  So it may just be the way your post processor is outputting the code.
Steve
